Email replied to.andy@thunderpole.co.uk wrote: ↑Thu Aug 22, 2019 1:56 pm Hi again,
I have sent you an email directly, as we wouldn't discuss individual complaints on here.
Regards,
Andy.
Lost Whip section from Orbiter
Enterprise
- wildfire
- Motor Mouth!
- CB Handle: wildfire.
Hi Guy's
I'm going to be honest & blunt like I always am this is another fault with whip antennas as one scrub screw isn't actually enough I believe every whip antenna should have 2 scrub screws so if one becomes loose the other scrub screw would still hold the whip in place & would stop this from happening
hi read with intrest a bit of locktite on grub screw should help hokd it as well not had that problem with any antenna unless i t was my fault not tightening the screw enough
Orbiter/Stinger whip departure is in my experience not uncommon. My solution is to set up and swr. Then wrap a piece of masking tape around the base of the whip to mark it's position in the coil. Remove the whip and hold it beside the coil, use a marker pen on the whip to note the position of the grub screw. Put the whip in a vice and using the narrow face of a flat file make a groove or flat spot for the grub screw bite on.
Now reassemble, with locktite, and not only will the screw bite the indent in the whip better it will have to overcome the step cut into it to escape. For belt and braces, replace the grub with a small machine screw, just don't strip the thread in the coil when tightening.
Hope that helps.
Hope that helps.
One person in ten understands binary. The other one doesn't.
