Humming noise
the spanner
Hi guys (and maybe gals)
On my old rig, everytime i press the PTT button to speak, all that comes out the other end of other CBs is a humming noise :shock: Ive tried speaking over the top but it doesnt make any difference.
Do you think if i brought a new mic it would make any difference?
provideing you have not got a swarm of bees in the set then the most probable cause could be a break in the audio lin in the mic try a replacement mic first if you then get audio with a hum in the second set try the power supply as if these are to small in ampage this will give you the problem of hum on tx :D
