AM / FM Antenna
mg_jones_uk
Hi all, i am returning back to CB radio after a long break as i think a lot of people are (hopefully), i have recently picked up a Midland 2001 AM / FM radio, although a bit worse for wear looking works great, i am confused by which antenna to get, my first question i have is, is there one antenna that will work for both AM / FM or do i need separate ones, i live in quite a high area so any antenna recommendations greatly received, also coax length is quite important i believe, help, thanks
- andy@thunderpole.co.uk
- Site Admin
Any CB antenna will work on AM or FM, that is just the modulation type.
If you wanted some advice on which antenna would best suit you, it may be best to give us a call on 01604 402403.
