Another swr post
Funny you should say that as I was about to suggest the same thing. Reason being I have been playing about with it and lengthened the whip as I cannot shorten it without cutting it. And lo and behold once I lengthened it the swr was higher on 1 and 40 than it was with whip in lowest position. For your reference the adjustment grub screw is in the same place above the coil as on a base loaded antenna, it’s just the coil is higher up. Need to get a good set of pliers. Will take my time and follow your advice and report back. Many thanks hair bear
