Hi Signal reading
boyscout
Hi all
I have a problem with a high signal meter reading on my homebase. I have a York JCB 863 and an Antron99 on a 10' pole. With a EP-815 Power Supply Unit.(you can take a look at my setup if you look at the thread mount and pole The meter is always reading just under 5 all the time,(It does go up if I get a good contact.) Im sure this is not normal as in the car it is usually sits around the 2 marker) I popped into thunderpole today and asked for some advice and bought a Bandit power noise filter.
I have fitted a ferrit to the power line to the PSU and a Bandit power noise filter to the line from the PSU to the York. This has had no effect to the signal meter reading. In fact the PSU did not like the Bandit as when power was taken off from the PSU the warning light came on and started to fade after about 5 secounds(and yes it was wireed up correctly) The only other thing I could think it might be is the hight of the Antron99. Although if you take a look at the pictures I think that it's high enough and away from the roof enough not to give me to much trouble. Any ideas????? :? :? :? :?
sounds like interferance from somewhere see if its from the power supply bu unpluging the antron if the signal is still high the its the power supply ifnot then it is rf from some where 6that will be a devil to find
boyscout
:) OK I did that and the needle bounced straight down to zero. although this morning when I fired the rig up, the RX signal reading is 3.5, No scrap my last it's just gone back up to 4.5-5
I did find a web site that sold the groundplane kit so that is on its way to me as we speak.
I have another 4'-5' left on the base of the pole so I think I will raise the antenna by another 4'-5' and hope that helps.
I have also ordered a lightning arrestor and I will earth the coax in hope this may improve things. :mrgreen:
try turning the heater off on the wall near your rig and see what happens could also be central heating motor
boyscout
Ok I have tried that, but to no avail. the motor for the central heating is in my young lads room. Is there a way of testing to see if it is anything to do with the pump. i.e. screening the pump some how. If it is the pump is there a way to suppress the interferance???
see if the signal drops when the pump is not runnung if it does then the pumps ast fault and it needs suppressing
boyscout
thanks for that I will give it a try.....but you know what the next question is going to be :D
rf interferance is a right old problem and sorry i dont know the value of the capictor should be dti used to be good at theses problems but now they cost to call out theses days
boyscout
DTI???? Do you have a web address or contact details for them. You never know there might be some usefull info on there web page.
i think they are under offcom now but not sure try digging on the goverment sites
fatfinger
Official CB Legend!!!
i have the same problem with my old rotel rig , used as a homebase reads seven all the time
swr is 1.1
goes down to 0 with a dummy load on the rig
i just live with it
boyscout
Yes I think I will also. I fitted the ground plane kit today and that did not bring the meter reading down. Was also going to fit a lightning arrestor but the collar broke as I was screwing it on. The last thing is to try and ground the antenna to see if that helps. I think that i wil just fit a jubilee clip to the bottom of the pole and drive a 3' peg into the ground. There is a good article in Radio user this month reference RF interferance and grounding. :idea: :idea: :idea: :idea: I will let you know how it goes.
fatfinger
i'm going to trip all the power to the house and see if this helps
thats the wayto do it or try i fuse braker at once
boyscout
yes but if you trip all the power in the house how will your rig power up??? :!:
