antenna problems
duracell
hi i have a problem with cb antennas because i live in scotland and i live near the coast and i have problems with strong wind,
this year the wind broke 4 antennas and i repaired one with solid aluminium bar at the base and it just snapped today, the antenna i baught said on the packet can withstand winds up to80mph
but this isnt good enough .........is there a way to put some kind of guy ropes from half way up the antenna to straghnthen it or to shorten the antenna without losing performance or swr?
cant shorten antenna would put the swr out try mounting on a car coiled spring at the base may help to take the wind load
just an odd thought i have them now and then
EarthWormJim
How about an adjustable mast and lay it down when the wind gets to ruff? it might cost a bit but you will save money by not havin to keep buyin anttennas :!:
Jim,
2H4OW
M3OJP
Radio one
Change your antenna to a fibreglass one.
Joe
tyhe mast seems a very good idea
EarthWormJim
The wind can pretty ruff here so we just lay it down and put a couple of gearbox stands under the pole for a bit of support that seems the better option than keep forkin out for antennas
Jim,
2H4OW
M3OJP
randombod
CB Handle: randombod
how about an adjustable height mast like whatthe army have on the landrovers or emergency services have on their command units . Army surplus places should get one for you . and they have fixings for guy ropes too
rotel 240
hi
try a shakey big stick or a antronn 99 they might be better in the wind
