Hi all
after 20 years up the loft I've decided to dig out my old CB Radio to see whats going on out there
However I'm confused on one issue, its is a Manor Kestrel with an RF Output of 4 watts and antenna impedance of 50 ohms (according to the manual) but the antenna (on a magmount) says it is pretuned to 100 ohms and when keying the mic the needle on the radio shoots straight across into the red
How significant is the 'rig' impedence of 50 ohms compared to the antenna figure of 'pretuned' to 100 ohms
Thanks in advance
help matching a new antenna with an 'old' radio
Am I dumb or is the S meter on the radio ment to go accross over to the right when keying the mic, as the meter is using the bottom scale on the s meter showing wattage output???stampman wrote:the rig works on 50 ohms output at 4 wtts so it look like you have an antena problem use the swr meter and you will be able to sort it
- EarthWormJim
To my knowledge the manor kestrel didt have a built in swr meter so your right when you key up the needle should go all the way across ????boyscout wrote:Am I dumb or is the S meter on the radio ment to go accross over to the right when keying the mic, as the meter is using the bottom scale on the s meter showing wattage output???stampman wrote:the rig works on 50 ohms output at 4 wtts so it look like you have an antena problem use the swr meter and you will be able to sort it
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
no the meter is set to make the rig look good it is a sales trick when you took a rig to be turned up the just turned up the meter so if you use an swr meter to set the antenna then check the set meter against is you should have a future referance point
