high squelch
longdistancewalker
Hi, i've got my mobile aerial stuck out of my flat but i'm getting very high mush, i've got the squelch closed but i'm missing loads of contacts, any ideas ???
breaker 19
just alter the squelch-turn it off and then adjust just until you loose the squelch noise and that should be right
try and find out where the interferanc is comming from ie: fridge ,tv,computeretc try unplugging and see if it makes a differance central heating pump can causem it as well
cheers and beers
:D :D :D :D :D
longdistancewalker
Hi, i've just found i've got a swr of 10 on my set up so i'm going to send it back to get a new plug fitted as i don't have the confidence do it myself & i don't own any cutters for it, thanks for the replys. :D
