Do I Need To Re-Calibrate Everytime ?
TheJester
CB Handle: The Jester
I understand that my aerial needs to be calibrated to my rig. But if I have a "temporary" setup...i.e Rig not fixed and aerial with mag mount. Is it necessary for me to re-calibrate the rig/aerial evertime I remove the aerial and place in boot because I`m parked in a rough area for example... Or is it ok if I place the aerial more or less where it was previously...
cheers
HANDLE : The Jester
Apbuild
Should be ok as long as the whip is kept tight in the mount and doesn't slide in/out
Rob
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
fatfinger
Official CB Legend!!!
i always remove my wilson magmount when not in use
and the swr always stays the same
so you will be ok
:D
TheJester
Phew, thats a relief.....
HANDLE : The Jester
the only time is when you change vechials
