Having received all my stuff (Rig, aerial, swr etc) I finally got setup and on the airwaves. Wasnt happy with the mag-mount (Didnt sit flat, due to tapered car roof) so went up to Forton Services and got a different one. Much happier now.
Transmitted my first "19 for a Roger" and got a few replies...Excellent it all works. The guy at the CB Shop (Forton Services) also tested my rig by calling his mate "Grass Cutter" who was about 4 miles away.
So now that I`m live, I thought I would ask a few bits of advice...
(1) I know everybody says "just be yourself", which is fine, but I would still like to use (And understand) a bit of the lingo. So what would my reply be if somebody transmitted a "19 for a roger or copy" ? And what is the procedure regarding moving to another channel.
(2) If I want to transmit a call out to somebody in particular e.g Grass Cutter", how would I go about this ?
(3) Are there any handles out there "Preston - Lancs Area" I should listen out for ?
I`m sure I`ll have more questions to come. Thats what happens when you`re such an imformative and helpfull forum...
Cheers,
The Jester
Went Live Today... Any Advice ?
- EarthWormJim
- Motor Mouth!
hi mate glad your all sorted.mstaines wrote:So now that I`m live, I thought I would ask a few bits of advice...
Cheers,
The Jester
(1) if someone calls 19 a roger or copy My reply is roger or copy breaker. Once contact is made it may be a good idea to give name/handle and if you wish to change channel say go down/up to what ever channel or say go up/down 1, 2 or etc.
(2) If calling on 19 I would say e.g 19, 19 thier handle/name are you about etc.
(3) I have no idea as im in lincolnshire so cant help on that one.
They are just to give an idea its not how you have to do it its just the way i do it. Just be yourself and dont worry you'll pick it up as you go along and if your not sure just ask.
hope this helps
Jim,
CB'ers do it till it Hertz...Side Banders do it till it MegaHertz
2H4OW
M3OJP
2H4OW
M3OJP
- EarthWormJim
- Motor Mouth!
no probs we all had to start somehwere. I started on cb before i even knew what a computer was
that was early 90's when i satrted
Jim,
2H4OW
M3OJP
2H4OW
M3OJP
