Minor problem?
Asterix
Hi guy's
I have got a (other company) minor that I have fitted in my car and It seems to have a supression problem, it is picking up noise from the alternator ( when i rev up the noise gets higher too ). I have taken off the coax lead from the rig and the noise is still there, I have rerouted the power lead to different areas and the niose is still there ( the power is taken from the cigarette socket ) the only time its gone is when the rig is switched off, It also picks up interference as i take the key out of the ignition switch. I have tried other rigs in my car and they dont seem to be affected by any supression problems, Is this a common problem with the minor? I know they are cheapish sets but has anyone else suffered from supression problem like this with these? Help anyone????
sound like a rig problem then i would change it and put it down to experiance
Asterix
Thanks Stampman, The rig is still useable and is not a bad little rig for what they cost, but the noise does seem to be amplified when useing an external speaker which can be a bit off-putting, like you say, best put it down to experience and prob. take out the ex. speaker aswell..... Cheers stampman.
