Waterproof CB radio
Hair Bear
I'll just throw this in...
I recently saw a rig that had a bluetooth link. I can;t remember the make but I thought you could put it in a sealed box and use a bt headset.
If I find it again I'll post it.
Globetrotter5
Cheers :)
Mr Benz
Hi , while I'm not aware of any IP rated CB radios ( there will certainly be PMR units designed to be used around boats etc ) the best suggestion I can make is that you look for rain protection cases for whichever radios you already have .
I work for one of the emergency services doing video production and photography and we have some very expensive equipment ( £60K cameras for example ) which we can't allow to be soaked , even though we have to work in all conditions .
When filming water rescue exercises , or actual incidents , we have sealed bags which can withstand accidental dunking in water , both for camera equipment and for things like walkie talkies .
For something like a mobile CB radio , I'd suggest something like a rain cover designed for a portable audio mixer ( see eBay link below ) . There are lots of specialist companies like Porta-Brace , Kata , Petrol and many others who have a huge range of specialist products and will even design and manufacture bespoke bags or covers for specific requirements , but do bear in mind products made for the broadcast and film industry are never cheap !
Within the UK , you could look to companies like Canford Audio ( one of the main suppliers to the BBC and broadcast industry ) , CVP , Op-Tech , as well as going direct to the manufacturers such as portabrace.com
Here is a listing on ebay , for something that might work for you .
https://www.ebay.co.uk/itm/405353635311 ... media=COPY
here's another one
https://www.ebay.co.uk/itm/176388124456 ... media=COPY
I expect you will get the idea , with the above bags , the rig could be mounted inside with the front panel visible under the transparent flap ( which closes with Velcro and can be opened for use ) , while the mic and other cables can come out through the port on the side . Won't be 100% waterproof , but will provide protection against even heavy showers .
Here are a couple of pics of a bag I use for my own field mixer ; it also has to hold a large battery pack , a couple of radio microphone receivers and a multicore cable to connect to the camera , hence it is a bit bigger than what you'd need for a CB radio , but the mixer is not entirely dissimilar in size from a CB , and there are lots of mixer bags made for different ones .
