1/2 wave ,,, 5/8 wave , difference??
If you use search, this has been covered before.
I'm sure Stampman say's 5/8 has a much flatter signal so performs that much better.
Rob.
Rob.
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
i did read the thread before but was not sure what a 'flatter signal ''was
it did not say flatter was better,
if it was fizzy drink then flatter would not be better,,
but hey,, now i know that if a signal is flatter than another it means it is better,
cheers ,
i will ask many questions and i will use what i learn to help other newbies on here,,, 8)
cheers ,
the DJ (discjokey)
if i can help ,i will.
magical mole
1\2 waves are 18 ft and 5/8 are 21ft its to do with wavelenth of antennas' had 1/2 wave before worked ok -but useing 5\8 at min best ive hade`5\8 seam to swr in beter with groand plane radals get one with or make sum its not hard` look wot gain the antenna is the higher it is the more it will incrse signal
