interference
smoothound
hi u guys when im homebase i get a lot of noise. about 3 s points this goes late on about 1 am.i know laptops near by are mainly to blame and the flat screen tvs in street.there may be some static. ive tried earthing out rig mast and guy wires made small improvement i use low loss heavy cable as well. can anybody tell me if insulating the guys from main mast helps although if this wind dont ease there will be no mast anyway iv tried the hf rigs notch and pbt filters and noise b. these also help a small amount. is there any thing else i could try.
generaly with interferance you have to cure it a sorce as trying to cut it down at the antenna would i think deafen the set but in this case am open to ideas that work
