SWR
Posted: Wed Mar 26, 2008 7:07 pm
by jason
hi again,,
i just wondered , when i bought my antron a99 i was informed that the swr is factory set , so i just stuck it up in the air , i did check the swr and it was high ,, after a conversation with a few owners they said raise it as some of the antenna was close to the wall ,, i raised it as much as the pole would allow , this leaves about a foot of the A99 close to the wall of the house and the swr did go down further,,it reads between 1.5 and 2 on ref and i wondered if the factory set is the lowest reading you can get or would turning those rings bring the swr down, see i would like to get it down further without having to purchase a new pole or re drill my brackets if possible,,i am using 15 metres of rg58 coax
so,, do i turn those rings ??? :?:
do i ground it ??? :?:
tips on this please x x x
Re: SWR
Posted: Thu Mar 27, 2008 6:39 am
new pole and get the base above the wall
Re: SWR
Posted: Thu Apr 03, 2008 8:40 pm
by jason
new pole installed and oiked it up a few more feet ,,
problem solved , cheers guys 8)
Re: SWR
Posted: Fri Apr 04, 2008 8:45 am
and another one bites the dust
Re: SWR
Posted: Sat Apr 05, 2008 12:18 am
by EarthWormJim
Is there such a thing as factory tuned? Ive always been told to checkthe SWR
Re: SWR
Posted: Sat Apr 05, 2008 10:13 am
yes but they are tuned on a perfect ground plane and as all ground planes vary with the amount of iron in the them or the surface area then its always safer to check the swr your self with a new antenna
:D :D :D :D :D :D :D
Re: SWR
Posted: Wed Apr 09, 2008 4:29 pm
by EarthWormJim
Thats what i thought stampman i just needed it confirming thanks mate :D :D
