Burners
nato 2000
Heyy all im kinda new to your forum and i love it and had a question about burners for you, i just bought a RM KL200 and was wondering if burners pull in aswell as push out signal and do i have to buy anything else so run it at full power or is my power pack (13.8v) ok to do this and is this a good burner? p.s i will be running this on a nato 2000 in the house and on a communicators in the car (will i need anything to run it in my car aswell or just a patch lead)
and answers will be greatly appreiciated. cheers guys
scott
the kl200 has a preamp built in which should drag the signals in but make sure you dont put more than 5 watt into it from the rig and either use a car battery or a power supply that will give you about 15-20 amps plus the antenna has to be lower than 1.5
nato 2000
ok thanks alot stampman i should have the amp tommorow aswell as my new astatic road devil mic :D i cant wait to try them out.
have you had any experiences with that mic?
many thanks for repling to me.
scott.
stampman wrote:the kl200 has a preamp built in which should drag the signals in but make sure you dont put more than 5 watt into it from the rig and either use a car battery or a power supply that will give you about 15-20 amps plus the antenna has to be lower than 1.5
the astatic mic's are a very good mic seem to make the audio on tx very clear
fatfinger
Official CB Legend!!!
astatic mic's are awesome
you cant go wrong buying one of them,
the rolex of mic's
