New mount and Antenna, & swr readings
Posted: Thu Jan 29, 2009 10:36 pm
Tonight, i have fitted a new antenna and gutter mount, as some little ******* decided to snap the old mount off, and trash my other antenna last week. I know whos done it, but cant prove it
Any way, fitted a standard thunderpole gutter mount, with a thunderpole trucker 80 whip antenna to it (same as I had last time), and checked the swr. After checking the readings on ch 1, 19, 20, and 40, I found them all to have the same swr reading as each other, which is bang on 2. Is this normal for all to be the same, as i cant lower the antenna any more, its right down to the bottom.
Is this a safe reading to use ok???????????????????????????????
