Earthing a Stinger with a gutter mount
fingle
Ive just installed an old Midland in the van (VW t25), and I currently have the stinger attached to the gutter (Have no other choice as it has a fibreglass roof). However to protect the paintwork I used some plastic to protect where it screws down onto the gutter.
I have scince heard about earthing (groundplaning) and wonder if this should be screwed into the paint so it touched the metal.
Could I run an earth cable from the stinger to somewhere inside the van instead, and if I did, would it be stupid to use the same route the arial cable takes (ie next it all the way down to the footwell)?
hi
run some cable down to an earth chase
just take the plastic out two small screws are not going to make the gutter rust this side of 15 years if you whant you the other halfs nale polish just round where the screws go into the gutter to keep the water out
Godzilla
I've a fibreglass roof on my transit, I put a body mount on with a stinger, just ran a earth to the nearest point and got below 1.5 swr, which is better than the mag mount I had on the roof bars :wink:
fibre glass roof is mounted into a metal gutter you will be ok with the mount on as normal just make sure the 2 screws make contact with the body
northern35s
The chassis on your radio will probably be directly connected to the SO239 socket on the back of your rig, so an alternative, should you be worried about damaging your paint, is to run a good earth to the chassis of your rig and take it from there, should it not work than consider a bonding lead from the gutter mount to somewhere else on the vehicle body.
