Weather caps for 3/8 antenna mounts, are they available?
Eviltwin
Just curious if there are 3/8 blanking plugs available for keeping moisture out of the antenna hole when nothings fitted, for example when the antennas removed for going through a car wash etc.
not for the 3/8 does not realy matter as it is a blind hole
Eviltwin
Fair enough.
snowman
is there not a chance that if you screw a antenna in with it water filled and as you cant compress water it causing a hydraulic affect and going tight before it is home? would this not affect the swr?
freebanders do it anywhere :)
Eviltwin
that was what I was thinking
not realy its not deep enough
Bionic Budgie
CB Handle: Bionic Budgie
Me Again...
I have some plastic caps that come on hydraulic fittings to protect the thread. They come in various sizes. I used one to cap a Sirio 3/8unf stud I used a while back, they fit fine. Free to you my friend..how many do ya want?
Budgie
Eviltwin
Just a couple to cap off a normal 3/8 mount, if you PM me your address I'll mail you a couple of stamps
Bionic Budgie
No worries.
Do you want a plug or cap? What diameter do you require?. I ask this because there are lots of different types. I can deliver if you want as I regularly work at RAF Wattisham. If you want to keep your location a secret (I understand if you do). I can leave them someplace.
Budgie
it will be a plug std thread
Eviltwin
Something to plug a 3/8 threaded hole
good idea chaps
joe jeep
CB Handle: Joe-Jeep
My 3/8 fitting has rusted up inside, it is probably as old as me!! So it has done quite well.
Handle:Joe-Jeep
chrome coated should not have rusted
