What sort of difference is that likely to make in the range achievable?
Would we need different antennae?
fingers crossed!!!
So, if we get 12W SSB.....
- Adriano9966
- Official CB Nut
The main benefit of using ssb IMO is not just pep but also lower noise (3db less) which equates to roughly half the noise level you would receive on eg am.
So even without the benefit of slightly more power, range would still be improved due to better reception.
I think this is especially important now due to the larger distances between stations. Its no accident that the mode of choice for telephony on hf is ssb throughout the world including shipping and the armed forces
hmm interesting
So, is there a theoretical percentage increase in range? I realise that everything depends on local conditions but if you are achieving 5 miles at the moment, would you be able to predict a 10% increase in workable range? 20%? using SSB?
- Adriano9966
- Official CB Nut
needle bender
- Motor Mouth!
Hi morat,,ssb most certainly has a consideral range advantage over am/fm modes of operation...you would be better off to google am/fm/ssb modes of operation to gain a better understanding...the only downside to ssb is fidelity of recieved audio...if you can call it a downside...you need to develop ssb ears...but you do eventually attune to it...but its all good that we are to have multimode cb at long last...
needle bender
- Motor Mouth!
Hi morat,,dont know much about the clansman radios,,so i googled them...seems to be a few models...one i looked at was the prc 320 and can be purchased for £425...covers 2-30 mhz,100hz channel spacing gives 280,000 channels. and at 30 watts pep into a whip antenna under normal conditions has a range in excess of 40 km...thats on a par with ssb cb radio...and of course with a good vertical antenna anything is possible...yeah tiz an interesting tranceiver ....would like one myself
