Polmar Venus
PGTips
CB Handle: PGTips
I bought a Polmar Venus a few months ago and was wondering if there are any know faults with this system. I have it fitted to a Land Rover Discovery 2, and on the last 2 times off-roading (both in the last month), I have had issues where it doesn’t pick up anything, or the signal is really distorted.
On a run last Sunday there were 2 vehicles directly in front of me with cb’s. Initially I wasn’t getting anything when they were transmitting, then it became a slight signal that was unreadable due to interference. AtT this time I was unable to transmit anything. Then suddenly, after about 30 mins, the signal became clear and I was able to hear and transmit clearly.
I have since carried out a factory re-set and it appears to be working, but it was already working at that point. I have checked all the connections and they are all good. I have also checked with an SWR meter and the transmit reading is just above 1.5.
Any ideas?
Discovery 2 TD5 ES
The D2 Boys Club
SLROC Member
Scottish Green Road Club
sounds like you wher too near the cars in front and the radio was being overloaded first thoughts
PGTips
CB Handle: PGTips
Thanks for the reply. Is there any way to get round that - other than dropping back? The 2 cars in front were much the same distance apart as I was and they tell me that they had no trouble with their radio's. I was parked along side one of the other vehicles later on and my radio worked fine at that time...
Discovery 2 TD5 ES
The D2 Boys Club
SLROC Member
try doing it with the engine running next time could be the altinater running hard to charge the battery and give ing you the interferance
PGTips
CB Handle: PGTips
Thanks for the reply. I'll give it a try 8)
Discovery 2 TD5 ES
The D2 Boys Club
SLROC Member
Vuck Roger
Know this is an older post, but I just purchased a POLMAR Venus and have the same exact issues.
I is this going for you and what antenna are you running?
Thanks!
Hugo
