pre amp
extremedave
does anyone know if pre amps do much good? im wondering if i should get one for the set up on my massey
raiderz
I always thought they amplify a lot of noise too as well as signal!
Can the massey handle it?? hehe only kidding i've got my 6455 dyna 6 sorted now, nice new dash, old firmware on it though as its handy to be able to get 50k out of it rather than the measly 40k it came with lol!!
Round Baler
6455 DYNA-6?
I've got a 6465 DYNA-6...hehe...I'm bigger than you! :P
- Gordon
Round Baler
raiderz
Does yours get to 50k?
Round Baler
Yes :P
- Gordon
Round Baler
extremedave
how do u make the 6400 series do 50k? is it an easy job?
raiderz
Yep on my 6455 it has the new gearbox where you get 40k at 1900 revs, any faster than 25.6mph and the autodrive knocks it from F into D, all I did was put a switch in cab which is connected in line with the speed sensor on the back axle, when the switch is "on" it breaks the signal line of the cable, so the dash doesn't know how fast the tractor is going, mine says "11.7" mph all the time when the switch is in the "on" position.
On the new dashes with the newer firmware on it gives off an ER code and you can't tell which gear its in. Its better to keep an older version on which will still tell you what gear you are in.
Must say before I did the mod going from 25.6mph to 20mph when autodrive kicked from 4F to 4D was kinda dangerous especially when you get a loony driving behind you on a mobile phone not looking at the road!
extremedave
cheers mate,my 6480 is one of the older ones with the old dynashift gearbox got it before the dyna6 came out,also does anyone know how to supress motors? i've heard thats a way to cut interfernce
caseboy
no need for a switch on any massey 64 dyna's just get you friendly mf fitter to stick the lap top on and you can change the settings in the auto 5 !! 2 min job max ! do it on pdi to prefered customers 8)
pre amps do seem to work but you wont know till you try it how good it will be
