Powering your cb
JamieT
Hi there, ive moved my cb into a better position for me in my tractor, the orignal power cable wouldnt reach so i wired it up with twin core coaxed wire and now i dont seem to get anybody on the cb, is this because of the wire? if so does anybody know what wire will work as an alternative to the original power cable, many thanks.
no that should work ok check the antenna coax if you have moved the set
