Nube set up question
Toddle
Hi all, just wondering if I've set my radio up correctly because I can't pick up much of a signal.
I bought a T 800 kit from Thunderpole with a body mount and an orbiter aerial.
I mounted the base on the roof making sure I scraped all the paint away for the lock nut to earth properly.
I drive a van so I had to use a 7meter cable to reach the radio.
The radio is wired on an ignition live and powers up fine.
The trouble is it can only get 1 bar of signal on about half of the channels. I did manage to hear someone on one channel but it was fairly distorted and so far I haven't reached anyone either.
I'm wondering if it's an earthing problem, is my cable too long or is there just nobody in my area?
Thanks for any help
Hi Toddle,
i have checked what equipment you have bought & it looks like you have a small orbitor antenna for better performance i would recommend a larger antenna as small base loaded antennas only do a distance up to 5 to 10 miles while larger antennas can do a distance up to 20 to 30 miles :wink:
