SWR alarm
26ru01
I have a SS600 i use for mobile. recently the Hi SWR alarm keeps activating. The SWR is low below 1.5. I tryed it on moblie antenna and home base antenna does same on both. The SWR is perfect so how can i deactivate this annoying feature on the radio.
Never heard of a ss600 but the threshold for the SWR alarm can be adjusted in the software on some modern radios and internally in some of the older radios ,
If it is a SS6900 then the manual says scroll menu to TOT / SWR to switch off SWR and TOT ( time out timer )
http://www.cbradio.nl/crt/Manual_CRT_6900_ENG.pdf
26ru01
ss6900 sorry my misstake fingers type to fast i should check before clicking submit. thanks for reply
