Power Problem?...
Big Jonah
I just re-installed my 40 channel rig in a new 4x4. I've mounted the aerial in the same position as my last 4x4, on the spare wheel carrier.
My problem is that I don't seem to be getting enough power to the set.
The LED diplay is quite dim, and if you put the volume up high, the static noise you usually hear fades in and out.
The 12v supply is good, as far as I know (used to be the supply to the rear heater fan before i stripped it out).
As I'm using a Thunderpole Orbital aerial I haven't bothered using a SWr meter, as I believe these are pre-tuned.
I can hear other users, but only with the squelch right down, and the volume low as well.
I'm only a novice at this, and use it vehicle to vehivle comms when I'm out off-roading.
Any ideas on what the problem might be, or where I should start looking?
If you havent checked the actual voltage going to the radio I would get that checked first.
If that is ok then I would suggest you need to get your radio looked at as it would appear to be faulty.
What is the make and model of the CB?
Andy :)
Big Jonah
The voltage is fine (I think!!)
I've got one of your Team ME04 sets.
I'll try connecting to another 12v power source to check first. Will report back this weekend at some point!
Rig: Team ME-4
Basilsparents
As actual voltage loss is rare in vehicle setups in the wiring, I would think a radio or fusebox fault? :S
I personally am a fan of disassembling wiring... not the other way around... XD
biggmark
wire directly to battery and see if theres an inprovement
Basilsparents
That's pretty much the best way :?
Big Jonah
Thanks guys, did what Mark suggested and it worked fine!
All wired in nicely now, and working fine!
Rig: Team ME-4
