Power Problem?...
Posted: Thu Apr 20, 2006 10:29 pm
I just re-installed my 40 channel rig in a new 4x4. I've mounted the aerial in the same position as my last 4x4, on the spare wheel carrier.
My problem is that I don't seem to be getting enough power to the set.
The LED diplay is quite dim, and if you put the volume up high, the static noise you usually hear fades in and out.
The 12v supply is good, as far as I know (used to be the supply to the rear heater fan before i stripped it out).
As I'm using a Thunderpole Orbital aerial I haven't bothered using a SWr meter, as I believe these are pre-tuned.
I can hear other users, but only with the squelch right down, and the volume low as well.
I'm only a novice at this, and use it vehicle to vehivle comms when I'm out off-roading.
Any ideas on what the problem might be, or where I should start looking?
