Mag mount & antenna help.
KB312
Hi all.
I am wanting to use my rig in my campervan now for static DX’ing.
I have a VW T4 and plan on using my 7” mag mount on the bonnet, angle adaptor, with an shorter antenna than my Tank Whip for traveling purposes. The campervan is a high top so no metal roof for the mag mount.
The top shelf of my van is 132cm long, so I'm either looking for an antenna at this length, or an antenna that can separate to fit. PS my tank whip just wont fit.
Questions.
Will the mag mount on the bonnet provide enough grounding?
What is the best static antenna I can get for the purpose?
I understand a “top loaded” antenna would be best as the van is a high top. Is this correct?
Thanks in advance from Rob.
Hair Bear
Does your van have a towbar?
If so, how about this...
Connect the bonnet mounted antenna through a switchbox and run the second coax through to the rear of the van. Use an antenna like an Antron 99, this is 3x 6' grp sections that just screw together. Clamp the bottom of it to the towbar bracket which will give it a nice solid anchor, and the loaded section will be 12' off the floor, well clear of the high roof.
To move off, lay the three sections on the floor and switch back to the mag mount.
KB312
Hair Bear wrote: ↑Sun Apr 11, 2021 9:44 am Does your van have a towbar?
Hi and thanks for the reply.
It does have a towbar, however it will be in use towing some of the time.
Hair Bear
Ok, if it's a 2 bolt type (ie not swan neck) see if you can get an old towbar bike rack mount. That will bolt in behind the towball then fab up a slip on bracket to fix the base of the antenna to. My bike rack mount has 2 upright round pins about 6" long, so the main part of the rack can drop over these pins - but - with the use of some old conduit and a few minutes of fabbing I can fit a spare wheel carrier, or flag pole, or antennas, and still fold it all up and tow with it.
KB312
Hair Bear wrote: ↑Sun Apr 11, 2021 10:54 am Ok, if it's a 2 bolt type (ie not swan neck) see if you can get an old towbar bike rack mount. That will bolt in behind the towball then fab up a slip on bracket to fix the base of the antenna to. My bike rack mount has 2 upright round pins about 6" long, so the main part of the rack can drop over these pins - but - with the use of some old conduit and a few minutes of fabbing I can fit a spare wheel carrier, or flag pole, or antennas, and still fold it all up and tow with it.
Thanks for the reply again.
However I’m just looking at if the bonnet mag mount situation will work and a decent antenna to boot. I’m not looking at all about a towbar solution.
KB312
Here’s where the mount will go!
Would it be better on the hatchback or vertical on the passenger door?
Hair Bear
Looking at the guys that come across from the continent with small luton type boxvans, they tend to have a mag or lip mount on the top n/s edge of the bonnet. I'm not sure how a VOSA roadside check would view the mount in the middle.
KB312
Hair Bear wrote: ↑Sun Apr 11, 2021 7:52 pm Looking at the guys that come across from the continent with small luton type boxvans, they tend to have a mag or lip mount on the top n/s edge of the bonnet. I'm not sure how a VOSA roadside check would view the mount in the middle.
However much you attempt to help, I’m not sure you read people’s posts to be honest. I think I state quite clearly that I’m seeking help for a mag mount solution and that it would be for static DX’ing.
It would be hard to pass a VOSA road side check with the car not moving and pulling into the side of the road.Please explain???
Mr Benz
KB312 wrote: ↑Sun Apr 11, 2021 9:23 am Hi all.
Questions.
Does the van have a metal rain gutter where the top of the steel sides meet the ( presumably ) fibre glass top ? If so a proprietary gutter mount is your solution .
