Gutter Mounts
andyd99
- CB Handle: andyd99
Is there a correct way of running the co-ax into the motor from the gutter mount without running it through open windows etc. Just wondering because ive got mine running through the door seals, wondered why yesterday and today i couldnt pick anytyhing up, and just found the coax has split because of shutting the door on it all the time. Would a mag mounted one be better suited, and if I got a mag mount, would it be ok for green laning, off roading etc going through narrow lanes and low trees etc???????????
andyd99
Silly question, and the reason why I ask is because the door seals are better on the passenger side rear door than on the drivers side. Does it make a difference which side the antenna is mounted on the vehicle, to the signal etc. As I say the door seal looks to be better on the passenger side than on the drivers side, so might not rip another co-ax if I put it that side.
hotmetal1000
- Chatter Box
yes
randombod
- Motor Mouth!
- CB Handle: randombod
i have a freelander and run it under the back part of the cab as it is detachable have you tried putting some tape around the part where it meets the door for a bit of extra protection. failing that the boot gaps can be a good place as they can be wider and cables dont always catch . then run th cable in the roof lining down the a post of the car (depending on where the rig is)
