Gutter Mounts
andyd99
CB Handle: andyd99
Is there a correct way of running the co-ax into the motor from the gutter mount without running it through open windows etc. Just wondering because ive got mine running through the door seals, wondered why yesterday and today i couldnt pick anytyhing up, and just found the coax has split because of shutting the door on it all the time. Would a mag mounted one be better suited, and if I got a mag mount, would it be ok for green laning, off roading etc going through narrow lanes and low trees etc???????????
no use the gutter mount just feed iy through the door you use least
andyd99
CB Handle: andyd99
Silly question, and the reason why I ask is because the door seals are better on the passenger side rear door than on the drivers side. Does it make a difference which side the antenna is mounted on the vehicle, to the signal etc. As I say the door seal looks to be better on the passenger side than on the drivers side, so might not rip another co-ax if I put it that side. :? :?
will be slightly directional at greater range from station you are talking to
andyd99
CB Handle: andyd99
But will be ok to do it? :? :? :?
hotmetal1000
yes
sure will
i used a dv27 on the gutter mount when i first got into cb.radio and it worked realy well very good antenna ...i dont know if they still do
make them i havent seen them around for a while :wink:
dv27 is still about and still a good antenna plus new version with a steel whip as well
stampman wrote:dv27 is still about and still a good antenna plus new version with a steel whip as well
hi stampman do they sell them at thunderpole and would they be ok for ssb *King*
no dont think they do and would not try 555 with one
randombod
CB Handle: randombod
i have a freelander and run it under the back part of the cab as it is detachable have you tried putting some tape around the part where it meets the door for a bit of extra protection. failing that the boot gaps can be a good place as they can be wider and cables dont always catch . then run th cable in the roof lining down the a post of the car (depending on where the rig is)
