Ali or steel
FISH
You shouldnt have much problems, swr that amount of area it has a bandwidth of about 2.5 mhz the antenna has.
what discone are you putting up and are you only useing it for receive.
26 TANGO MIKE 501
cheekychurros
Putting up a Sirio Discone SD 1300, mainly RX but can TX on 446, which is what my Motorola GM340 is on.
Sorry to be a PITA but what does this mean??
I am a newbie and this is baffling me, I havent a clue what this means.
I will SWR the 827 on the ground then whack it up
it will swr with range of 2.5 megahertz ie; from 30mhz to 32.5 mhz
:D :D :D *King* *King* *King*
FISH
The 827 is pre tuned for mid band so its band width is 26mhz to 29mhz = 2.5mhz.
Just thinking that you may have a problem with tx-ing on 446mhz with the 827 that close to the discone.
Is the dicone pretuned bud.
26 TANGO MIKE 501
cheekychurros
Yes, pre tuned for quite a few
# RX Frequency: 25-1300 MHz
# VHF TX Frequency: 49-51/120-180/215-300 MHz
# UHF TX Frequency: 415-465/610-650/710-1000/1130-1300 MHz
# Connector: UHF SO-239
It will be aprox 6 foot to the side of the 827.
FISH
Yes it is pre-tuned but are you going to tx with the dicone bud on 446.
26 TANGO MIKE 501
cheekychurros
Sorry, Yes I was planning to. I have a Gm340 and my wife has a GP300 HH. I was going to try to TX to each other.
Am I going to run into a problem TX'ing with the 827 close by??
FISH
You may have even if it is pre-tuned.
26 TANGO MIKE 501
cheekychurros
Are you not supposed to have a discone near a CB Antenna?
It isnt overly important really I can live without it. I am getting a Cb for the car so could use that to TX to the wife and just use the discone for RX. Thanks for that I never thought of that.
WHat do most people do with they SWR their 827, do they set it for 19 or 555. and If I want to TX on both is there a set length the end piece should be or is it play it by ear and see what the SWR does? I can see myself using both you see so want to set it to do both. The chap coming knows what he is doing I think so hopefully he will know how to set it for both.
I cannot wait to get on the air. I heard some on the Sirio 4000 but I bet its nowt compared to what I can get on the 827.
20FT pole has just been delivered. Its HUGE. The wife said "where's THAT THING going" I refrained from the obvious answer.
FISH
Its just that there a bit close together and there both on the same aluminium pole,and you are both tx-ing, cb antennas length are made for certain frequency of use,basicaly you have a lot of aluminium all together you may have problems or it may be ok .i have a imax on the back of my house and thats coming down.the new antennas going up is. beam = bedroom window = discone
then the imax on the roof if i can get someone up there lol.
26 TANGO MIKE 501
cheekychurros
I have someone coming to do mine who used to be a antenna installer. He knows his aerials. I can always ask him if he travels, if you want me to? You never know.
FISH
Has he put up cb antennas before m8.
26 TANGO MIKE 501
cheekychurros
Yes he has. He put up specialised radio antennas up for a living specialising is taxi radios, cb, and government work. I asked him this too as its a special area.
FISH
Just make sure the swr is ok on both antennas even the pre tuned discone.
26 TANGO MIKE 501
cheekychurros
oh, thats confused me now lol how do i swr the discone?
