You shouldnt have much problems, swr that amount of area it has a bandwidth of about 2.5 mhz the antenna has.
what discone are you putting up and are you only useing it for receive.
Ali or steel
cheekychurros
Putting up a Sirio Discone SD 1300, mainly RX but can TX on 446, which is what my Motorola GM340 is on.
Sorry to be a PITA but what does this mean??
I am a newbie and this is baffling me, I havent a clue what this means.
I will SWR the 827 on the ground then whack it up
The 827 is pre tuned for mid band so its band width is 26mhz to 29mhz = 2.5mhz.
Just thinking that you may have a problem with tx-ing on 446mhz with the 827 that close to the discone.
Is the dicone pretuned bud.
26 TANGO MIKE 501
cheekychurros
Yes, pre tuned for quite a few
# RX Frequency: 25-1300 MHz
# VHF TX Frequency: 49-51/120-180/215-300 MHz
# UHF TX Frequency: 415-465/610-650/710-1000/1130-1300 MHz
# Connector: UHF SO-239
It will be aprox 6 foot to the side of the 827.
cheekychurros
Sorry, Yes I was planning to. I have a Gm340 and my wife has a GP300 HH. I was going to try to TX to each other.
Am I going to run into a problem TX'ing with the 827 close by??
cheekychurros
Are you not supposed to have a discone near a CB Antenna?
It isnt overly important really I can live without it. I am getting a Cb for the car so could use that to TX to the wife and just use the discone for RX. Thanks for that I never thought of that.
WHat do most people do with they SWR their 827, do they set it for 19 or 555. and If I want to TX on both is there a set length the end piece should be or is it play it by ear and see what the SWR does? I can see myself using both you see so want to set it to do both. The chap coming knows what he is doing I think so hopefully he will know how to set it for both.
I cannot wait to get on the air. I heard some on the Sirio 4000 but I bet its nowt compared to what I can get on the 827.
20FT pole has just been delivered. Its HUGE. The wife said "where's THAT THING going" I refrained from the obvious answer.
Its just that there a bit close together and there both on the same aluminium pole,and you are both tx-ing, cb antennas length are made for certain frequency of use,basicaly you have a lot of aluminium all together you may have problems or it may be ok .i have a imax on the back of my house and thats coming down.the new antennas going up is. beam = bedroom window = discone
then the imax on the roof if i can get someone up there lol.
26 TANGO MIKE 501
cheekychurros
I have someone coming to do mine who used to be a antenna installer. He knows his aerials. I can always ask him if he travels, if you want me to? You never know.
cheekychurros
Yes he has. He put up specialised radio antennas up for a living specialising is taxi radios, cb, and government work. I asked him this too as its a special area.
cheekychurros
oh, thats confused me now lol how do i swr the discone?
