help
padster
CB Handle: night owl
i cant get my magmount to swr less than 3 have mounted it on a metal sheet what am i soing wrong should it be earthed
padster
padster wrote:i cant get my magmount to swr less than 3 have mounted it on a metal sheet what am i soing wrong should it be earthed
i have managed to get swr to one point nine its on radaitor on steel plate any suggestions to lowering swr
if its higher on 40 than 1 cut the whip
disgwylfa
CB Handle: 186-TM-555
stampman wrote:if its higher on 40 than 1 cut the whip
But, for goodness' sake, only cut a LITTLE bit off at a time! Like a quarter of an inch or 5mm sort of size. You can always take some more off, but it's impossible to put some back on.
Cherokee
padster
Cherokee
hi my whip is in two pieces with a thick part in middle both sections join into where should i trim top or bottom of whip thanks
padster
my whip comes in three parts where abouts should i trim it
disgwylfa
Trim from the top . . . . If you started at the bottom you'd be trimming the mag mount :D
yes just trim the tip of the whip and dont take too much off use the meter each time you have removed a bit
killer cam
CB Handle: killer cam
yes just take 5mm off a time
good luck with it ...i hate triming antennas down :wink:
killer cam
risky
not if you are careful
killer cam
true true
bit like a vasecitomy realy
disgwylfa
killer cam wrote:just take 5mm off a time
stampman wrote:bit like a vasecitomy realy
--------- OUCH!!
