help
- padster
- Chatter Box
- CB Handle: night owl
i have managed to get swr to one point nine its on radaitor on steel plate any suggestions to lowering swrpadster wrote:i cant get my magmount to swr less than 3 have mounted it on a metal sheet what am i soing wrong should it be earthed
But, for goodness' sake, only cut a LITTLE bit off at a time! Like a quarter of an inch or 5mm sort of size. You can always take some more off, but it's impossible to put some back on.stampman wrote:if its higher on 40 than 1 cut the whip
Cherokee
- padster
- Chatter Box
hi my whip is in two pieces with a thick part in middle both sections join into where should i trim top or bottom of whip thanksdisgwylfa wrote:But, for goodness' sake, only cut a LITTLE bit off at a time! Like a quarter of an inch or 5mm sort of size. You can always take some more off, but it's impossible to put some back on.stampman wrote:if its higher on 40 than 1 cut the whip
Cherokee
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
yes just take 5mm off a time
- killer cam
risky
- killer cam
true true
