cheers
xtra power
- BlackDragon
- CB Handle: AcidK1
Not overly a technical issue, but more advice. I plan to get a small amp to try and boost the DXing, i plan to get a 25 or 30 watt, will this make any difference, im not willing to break any records on price because it isnt going to be in constant use, just looking for advice on power
cheers
cheers
CT 118
The amount of power you need to make a difference very much depends on what you're planning to do with it.
If you're using Sideband and "riding the Skip", 25 or 30w will be adequate to get some good contacts around Europe.
But if you're looking for a noticeable increase in (TX) range for Ground Wave contacts on FM, you really need to go to at least 50w, if not 100w.
Also remember that 100w through a badly placed cheapo 24" antenna at ground level is likely to be less effective than 10W through a full-size 5/8 wave mounted on a mast.
(Oh, also ought to mention... I assume you do know that anyong over 4w is technically illegal on the CB bands. There are thousands of them out there but, just in case you weren't aware, in the UK Ofcom requires a maximum of 4w using a "type-approved" FM transceiver [with a CB27/81 or a PR27/XX mark] to remain legitimate)
Steve ("Cherokee")
Steve ("Cherokee")
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
hahahahahaahahadisgwylfa wrote:Ohhh! A Porky-Pie from Mr Porky!porky.69 wrote:AND ME !! lolFISH wrote:I ONLY USE 4 WATTS.
- killer cam
well porky was clearly lieing
haha (lol)
haha (lol)
- porky.69
me lie no way i only use 25 watts oooohhh well the galaxy puts out 50 so but i have no burner but' iam thinking about itkiller cam wrote:well porky was clearly lieing
haha (lol)
maybe a 100 watt one but its got to be a zetagi one !!!
Hang on a minute. You're saying "me lie no way" and then admitting to "use 25 watts" and "galaxy puts out 50"???porky.69 wrote: me lie no way i only use 25 watts oooohhh well the galaxy puts out 50
Earlier post read
So, call me Sherlock Holmes if you like, but methinks the claim that you only use four watts was just a little tiny Porky.Pie Lie then wasn't it?porky.69 wrote:AND ME !! lolFish wrote:I ONLY USE 4 WATTS.
Let's be fair Mr Porky.69, if you weren't fairly sure it'd melt your neighbour's telly and toast the cat across the road, you'd have a kilowatt amp on wouldn't you ;)
Steve ("Cherokee").
- killer cam
lol
- porky.69
pmsl steve it depends what radio im useing loldisgwylfa wrote:Hang on a minute. You're saying "me lie no way" and then admitting to "use 25 watts" and "galaxy puts out 50"???porky.69 wrote: me lie no way i only use 25 watts oooohhh well the galaxy puts out 50
Earlier post readSo, call me Sherlock Holmes if you like, but methinks the claim that you only use four watts was just a little tiny Porky.Pie Lie then wasn't it?porky.69 wrote:AND ME !! lolFish wrote:I ONLY USE 4 WATTS.
Steve ("Cherokee").
