xtra power
BlackDragon
CB Handle: AcidK1
Not overly a technical issue, but more advice. I plan to get a small amp to try and boost the DXing, i plan to get a 25 or 30 watt, will this make any difference, im not willing to break any records on price because it isnt going to be in constant use, just looking for advice on power :)
cheers
CT 118
disgwylfa
CB Handle: 186-TM-555
The amount of power you need to make a difference very much depends on what you're planning to do with it.
If you're using Sideband and "riding the Skip", 25 or 30w will be adequate to get some good contacts around Europe.
But if you're looking for a noticeable increase in (TX) range for Ground Wave contacts on FM, you really need to go to at least 50w, if not 100w.
Also remember that 100w through a badly placed cheapo 24" antenna at ground level is likely to be less effective than 10W through a full-size 5/8 wave mounted on a mast.
(Oh, also ought to mention... I assume you do know that anyong over 4w is technically illegal on the CB bands. There are thousands of them out there but, just in case you weren't aware, in the UK Ofcom requires a maximum of 4w using a "type-approved" FM transceiver [with a CB27/81 or a PR27/XX mark] to remain legitimate)
Steve ("Cherokee")
FISH
I ONLY USE 4 WATTS.
26 TANGO MIKE 501
FISH wrote:I ONLY USE 4 WATTS.
AND ME !! lol :wink:
FISH
I woudnt know what to do with more than 4 watts. :^o :^o
26 TANGO MIKE 501
disgwylfa
Ohhh! A Porky-Pie from Mr Porky!
hahahahahaahaha
FISH
WHAT ???
26 TANGO MIKE 501
well porky was clearly lieing
haha (lol)
FISH
Never. :lol: :lol: :lol:
26 TANGO MIKE 501
killer cam wrote:well porky was clearly lieing
haha (lol)
me lie no way i only use 25 watts oooohhh well the galaxy puts out 50 so but i have no burner but' iam thinking about it
maybe a 100 watt one but its got to be a zetagi one !!! #-o :D
disgwylfa
porky.69 wrote: me lie no way i only use 25 watts oooohhh well the galaxy puts out 50
Hang on a minute. You're saying "me lie no way" and then admitting to "use 25 watts" and "galaxy puts out 50"???
Earlier post read
porky.69 wrote:
Fish wrote:I ONLY USE 4 WATTS.
AND ME !! lol
So, call me Sherlock Holmes if you like, but methinks the claim that you only use four watts was just a little tiny Porky.Pie Lie then wasn't it?
Let's be fair Mr Porky.69, if you weren't fairly sure it'd melt your neighbour's telly and toast the cat across the road, you'd have a kilowatt amp on wouldn't you ;)
Steve ("Cherokee").
lol :lol: :lol:
Earlier post read
AND ME !! lol
Steve ("Cherokee").
pmsl steve it depends what radio im useing lol *King*
FISH
Amstrad 901 here .
26 TANGO MIKE 501
