Thunderpole ATOM
WOODY R
Hi, I still seem to be having problems with my CB setup, therefore i have decided to buy a Thunderpole ATOM antenna and a side mount body fixing, which i am hoping to fix to the back door of my van. I have the aerial mounted on the ladder at the moment without a lot of success.
What i would like to know is the ATOM aerial already SWR'D in, if not how do i do this please.
Many thanks
WELL a very good antenna and i didnt swr mine and it works a treat ' for a small antenna *King*
you might get reflection try a center loaded antenna or top loaded one and it will sort your problems
dr pepper
CB Handle: The Hood.
A DV27AF is a veritable aerial, and is top loaded and cheap, on top of that its a piece of cake to swr, just a thumbscrew and a 'stinger' at the top, I've had one of these swr when nothing else would work.
Rig wiring tips: red to black, black to red, blue to bits.
good antennas i have heared
WOODY R
I received my Atom and side mount kit on Thursday, have not been brave enough yet to go and drill the holes in my back door, to fit the side mount.
I will let you know the results of the Atom when i have the courage to drill the holes :? :(
why not use a boot mount will fit without drilling holes
stampman wrote:why not use a boot mount will fit without drilling holes
yes by a boot mount mate
dr pepper
mounting the base on the metalwork direct will give you better results, if you do stick it on the body rather than the door.
I've allways had better results when directly mounted.
Centre of the roof is the best place.
If you get a boot mount then make sure you've got a good eart.
WOODY R
Thanks everyone for your replies, the reason i went for a side mount was, the roof of my van is fibreglass, therefore no good for the aerial mounting. I am hoping that the side mount will work, as with this i will not have any cable outside, as i have previously had to run the cable between the hinges on the door which can i suppose eventually damage the cable. I would have the same problem if i used a boot mount or door mount.
no the seal round the door will absorb the cable with out too mutch problem
stampman wrote:no the seal round the door will absorb the cable with out too mutch problem
true true
WOODY R
I have had another thought about an aerial mount. Would a mag mount work, if i put it on top of my stainless steel spare wheel cover ? Also thought about using a mag mount and a swivel connector and put it either on the back door or where i have metal just below the fibreglass roof.
Any advice on these ideas please, many thanks.
Asterix
Depending on the quality of the stainless, you may find that the mag mount won't stick to it very well,if at all. probably best to think of a more secured setup.
dr pepper
yep stainless is not ferrous and a magnet dunt stick to it, marine grade 316 is totally unmagnetic.
