Hi, I still seem to be having problems with my CB setup, therefore i have decided to buy a Thunderpole ATOM antenna and a side mount body fixing, which i am hoping to fix to the back door of my van. I have the aerial mounted on the ladder at the moment without a lot of success.
What i would like to know is the ATOM aerial already SWR'D in, if not how do i do this please.
Many thanks
Thunderpole ATOM
- dr pepper
- CB Handle: The Hood.
A DV27AF is a veritable aerial, and is top loaded and cheap, on top of that its a piece of cake to swr, just a thumbscrew and a 'stinger' at the top, I've had one of these swr when nothing else would work.
Rig wiring tips: red to black, black to red, blue to bits.
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
good antennas i have heared
I received my Atom and side mount kit on Thursday, have not been brave enough yet to go and drill the holes in my back door, to fit the side mount.
I will let you know the results of the Atom when i have the courage to drill the holes
- killer cam
stampman wrote:why not use a boot mount will fit without drilling holes
yes by a boot mount mate
- dr pepper
mounting the base on the metalwork direct will give you better results, if you do stick it on the body rather than the door.
I've allways had better results when directly mounted.
Centre of the roof is the best place.
If you get a boot mount then make sure you've got a good eart.
Thanks everyone for your replies, the reason i went for a side mount was, the roof of my van is fibreglass, therefore no good for the aerial mounting. I am hoping that the side mount will work, as with this i will not have any cable outside, as i have previously had to run the cable between the hinges on the door which can i suppose eventually damage the cable. I would have the same problem if i used a boot mount or door mount.
- killer cam
stampman wrote:no the seal round the door will absorb the cable with out too mutch problem
true true
I have had another thought about an aerial mount. Would a mag mount work, if i put it on top of my stainless steel spare wheel cover ? Also thought about using a mag mount and a swivel connector and put it either on the back door or where i have metal just below the fibreglass roof.
Any advice on these ideas please, many thanks.
