25 Watts or 150 Watts
and if it is not you can 1)buy a bigger one to run both at once 2) buy a smaller one that will just run the amp so you will have one on for the radio one on for the amp
Photographer
CB Handle: Terminator / 26TM233
Ah, didn't think of that, 2 psu's??
I have got a Watson Mite NF with 20A output, 23A max so I reckon it should be OK for the Ranger 2950 and the 100W amplifier?
Anybody know any different and I'll pick up another smaller PSU.
Cheers guys!!
http://www.stphotography.org
FISH
try not to buy a switch mode psu.
26 TANGO MIKE 501
that sounds ok to me but for example if the lights on the radio go dimer when you tx you need a bigger psu sure you wont tho and make sure you have a very low swr because amps increase your reflection on your antenna so make sure its about 1.9 at the most :D
Photographer
Should I get one of these to be on the safe side, are they any good?
Zetagi TM999 Matchbox - £50 at Thunderpole
no the psu will do fine
Photographer
The Matchbox is a combined SWR Meter and Matcher, was wondering if that will help keep the SWR low (below 1.5)?
Photographer
FISH wrote:try not to buy a switch mode psu.
What's wrong with Switch Mode PSU's??
northern35s
Photographer wrote: What's wrong with Switch Mode PSU's??
EMI, electromagnetic interference, created by the switching relays, the noise could be the difference between making the DX or not, especially when conditions are marginal :wink:
no swr the antenna properly as all the matcher does is fool the swr side and loses power
stampman wrote:no swr the antenna properly as all the matcher does is fool the swr side and loses power
FISH
Two different topics going on at the same time it looks like lol.
26 TANGO MIKE 501
:lol: :lol:
split personalitys
but very good point
FISH
sounds like it lol.
26 TANGO MIKE 501
