dipole antenna
chris9
Hi all,
I was just wondering:
The lower part of a centre fed (vertical) dipole, can that be below the top of a building (building has metal work holding it up).
I don't need to be able to get far, but don't want bad swr, so if some of the lower section is below the top of the building will that cause bad swr?
Just want to try a put up a fairly discreet antenna.
Chris
if you want discreet the dv27 at 4ft is better than an 18 ft diapole 9 ft each leg
chris9
thanks for the reply....
but that antenna is a mobile....
have already tried a mobile at this location and there is insufficient groundplane, so i'd have to muck about building one, which would likely be less discreet than the dipole.
so does the bottom half of the dipole have to be above the side of the building to get the swr low?
thanks
Chris
stick 9ft of wire on base of dv and it will work fine there is no sutch thing as a mobile antenna only they are all antennas which can be put to any mounting or fixture you want if you wanted you could fix an antronn 99 to a mini only thing that stops you is that you might have trouble with bridges and car parks
:D :D :D
clockworkorange
chris9 wrote:Hi all,
Chris
you will be fine if its below as its only acting as a ground plane :D
chris9
thanks, I thought as much, but after having a load of trouble with mounting a tank whip on top of an RSJ and getting terrible swr due to groundplane issues. I thought I'd check before trying a different course of action.
Thanks again
Chris
look on it as a chance to bore the great grand kids stiff when you are 90 years old
Bulldoguk
can you still get them ? i would'nt mind putting one up at my home 20
what grandkids yes you can still get them just take a few years to deliver andy could probable help
Bulldoguk
lol just got one of them grand kid things and me being so young aswell :lol: i dont know what his mum and dad will think if i put him on the roof :shock: :D
But if he makes me anymore of them nappies it deffo an idea :lol:
