Hi all,
I was just wondering:
The lower part of a centre fed (vertical) dipole, can that be below the top of a building (building has metal work holding it up).
I don't need to be able to get far, but don't want bad swr, so if some of the lower section is below the top of the building will that cause bad swr?
Just want to try a put up a fairly discreet antenna.
Chris
dipole antenna
thanks for the reply....
but that antenna is a mobile....
have already tried a mobile at this location and there is insufficient groundplane, so i'd have to muck about building one, which would likely be less discreet than the dipole.
so does the bottom half of the dipole have to be above the side of the building to get the swr low?
thanks
Chris
thanks
Chris
stick 9ft of wire on base of dv and it will work fine there is no sutch thing as a mobile antenna only they are all antennas which can be put to any mounting or fixture you want if you wanted you could fix an antronn 99 to a mini only thing that stops you is that you might have trouble with bridges and car parks
clockworkorange
- Official CB Nut
chris9 wrote:Hi all,
Chris
you will be fine if its below as its only acting as a ground plane
thanks, I thought as much, but after having a load of trouble with mounting a tank whip on top of an RSJ and getting terrible swr due to groundplane issues. I thought I'd check before trying a different course of action.
Thanks again
Chris
Thanks again
Chris
