Hi everyone and thanks for having me onboard, i have just purchased an old 40 channel rig off the bay of fleas, when i cue the mic the needle on the signal meter goes up and bounces straight back down, even though the mic is still cued, is this how it should react ? The rig is badged up as a Barracuda but not the common well recommended black fronted one, i cant find any info on google about it so thought i would ask here. The mic is brand new as the one that came with it had loose connections.
Many thanks
Cliff
Basic info required please
Nope, neither, it has the big channel select button on the right with barracuda beneath, hi/Lo switch on rear, power meter on left, pa/cb switch, dials for vol, squelch, rf gain and dimmer from left to right and that's all so nothing like the barracuda I've seen lots of. It's the behaviour of the meter when I cue that concerns me because I don't think its transmitting which leads me to believe I've been sold a lemon.
It will be late 70s Barracuda GT868 radio built by the chinese.
Same board is fitted to these CB Radios----
Commtel GT868-------------------------------Commtel GT858
Barracuda GT868------------------------------Commtel 40
Sapphire X2000-------------------------------cheiza 701
Lake Manxman 950---------------------------Lake Manxman 850
Transcom GBX2000--------------------------- Elftone EL-CB 6000
Academy CB502-------------------------------Academy CB501
Gecol GT868-----------------------------------Gecol GT858 B
Sumeet GT858-------------------------------Tokai GT858
SonicGT868---------------------------------Eurosonic GT858 & Euro 11
Fidelity 1000fm
mic wiring - http://highfields-arc.co.uk/constructor ... cuda02.htm
SVR1 = Recieve needle adjust
SVR2 = Squelch adjust
SVR3 = Mic gain adjust
SVR4 = Key up needle adjust
Fidelity 1000fm
Thats the Fella thanks Dragonfly, i dont particularly want to open and start messing to be honest.
Guzzy, i was just keying the mic, no traffic, i take it when i talk it should move the needle ??
Many thanks for taking the time to reply both
Cliff
Cliff
post us a picture of the Barracuda and your antenna.
These radios are usually fairly robust and long lasting as they dont usually get much use before people buy a better radio,Having sead that given the right antenna they can get out well enough,they were prone to bleadover from other users but can be handy these days to tell you that mobile breakers are passing by on another channell.
Dragonfly, the rig is exactly as your picture apart from it has barracuda badging. The antennae has a tight spring on the base, then thin, then a black cylinder then thin to the tip. I cant add pics from my mobile
Where will I find a rig doctor and is it worth it, I'm in Tamworth in Staffs.
Many thanks for your continued help.
If you have an email address I can send a pic or to a mobile, my mail is instructorbadger@hotmail.com
Many thanks,
Cliff
Many thanks,
Cliff
