swr and setup
- reef
- CB Handle: Reef
Hi Guys at my wits end ive studied read ,reread studied ,restudied and read and i still cant get my head around swr ... i set mine up and had readings of 1.5 (1)and 1.7 (40)but when i went outchannel 19 was on 2 and when i checked 1 and 40 so were they ..... im in st Helens any kind souls wanna come check my setup ...tea/coffee and sarnies on order
don't run with swr in line use it to set the cb antenna up then remove as you lose power through it it swr will vary as you drive due to reflection from various objects so don't worry about it or you will be old before your time
