swr and setup
reef
CB Handle: Reef
Hi Guys at my wits end ive studied read ,reread studied ,restudied and read and i still cant get my head around swr ... i set mine up and had readings of 1.5 (1)and 1.7 (40)but when i went outchannel 19 was on 2 and when i checked 1 and 40 so were they ..... im in st Helens any kind souls wanna come check my setup ...tea/coffee and sarnies on order
reef
CB Handle: Reef
oh and silly question but ive fitted a roof mount but not sealed it withnsilicone yet ..will rain affect my readings ? :oops:
when i went out can you clarifie that no you generally dont need sealer round the mount as the rubber gasket seals it
are you running with the swr meter in line ?
reef
CB Handle: Reef
its a mobile unit and swr goes up in certain areas ,i have left the swr inline
don't run with swr in line use it to set the cb antenna up then remove as you lose power through it it swr will vary as you drive due to reflection from various objects so don't worry about it or you will be old before your time
