what burner
landyloon
what burnner would u guys use with a team me4 radio and orbital ariel was thinking abot a 200watt would this be to much also has pre amp on it what does the pre amp do
amplifies the incoming signal
:D :D :D :D :D
Matt C
Are pre-amps any good?
I thought that they were just for AM?
Call sign: 2H2SQ
Handle: 'Turtle'
Home is where you park it!...
no they will work on fm as well
:D :D :D :D :D :D :D :D
plumb bob
A pre-amp will boost the incoming signals, it will also boost all the noise/hiss so if it's switchable it would be better, so you can transmit using the amp, and only use the pre-amp when you really need to.
I theory, if everybody used say, a 200 watt amp, then nobody would need a pre-amp.......... :mrgreen:
It's all about the MONEY
if every body used a 200watt burner then it would be bedlum you would not hear enybody for listening to everybody
plumb bob
stampman wrote:if every body used a 200watt burner then it would be bedlum you would not hear enybody for listening to everybody
Not in an ideal world.............. :D ..................... :lol:
