what burner
A pre-amp will boost the incoming signals, it will also boost all the noise/hiss so if it's switchable it would be better, so you can transmit using the amp, and only use the pre-amp when you really need to.
I theory, if everybody used say, a 200 watt amp, then nobody would need a pre-amp..........
It's all about the MONEY
Not in an ideal world..............stampman wrote:if every body used a 200watt burner then it would be bedlum you would not hear enybody for listening to everybody
